So I need a USB hub that is similar to this one but actually has a fast charging port even if it's dedicated to power only. I like the design of being able to plug usb into the back as well as the front. Also I do need this to be able to connect to a PC for data transfers. I have a USB 3.1 Gen 2 port that I would like to be able to fully utilize if possible for the fastest speeds possible.
https://www.amazon.com/gp/product/B00JEPIOOQ/ref=ppx_yo_dt_b_asin_title_o00_s01?ie=UTF8&psc=1
https://linustechtips.com/topic/1318369-need-a-usb-hub/
I am not sure if there are any with the same kind of back ports that you are interested in, but it is very much worth looking at Anker's offerings. I used the 7 port version of this https://www.anker.com/products/variant/anker-10-port-60w-data-hub/A7515111
They also have an amazon store.
finally escaped fm2+
https://linustechtips.com/topic/1318369-need-a-usb-hub/#findComment-14585964
Alright I'll look into that thank you
https://linustechtips.com/topic/1318369-need-a-usb-hub/#findComment-14587870
