Budget (including currency): $1,200
Country: USA
Games, programs or workloads that it will be used for: The most resource intensive games I play are probably Call of duty warzone and future CoD titles but hope to be able to expand once I have a modern desk top. I do some video editing and sound/music mixing but not big projects it's more of just a hobby.
Other details:  i have been compiling this PcPartPicker list for a while but not sure what what to chose for Motherboard or case. For the motherboard i want the X570 chipset and Wi-Fi 6 preferably but if you can make a good argument for going with Wi-Fi 5 I'm all ears. as for the case good air flow and quality are mainly what I'm looking for (RGB is a plus not a must) I'd like to not spend over $100 on the case but I'll take all suggestions into account. GPU is a hard one but i think I've settled on getting a RX 580 for temporary use then upgrading down the line to a 3070 or 3080 so room in the case for that as well. Last note the 3700x CPU comes with a AMD Wraith Prism Cooler right? and if so i hear mixed thought's on if it's good enough to stick with or not, anyone use it that can attest to one side or the other?
https://linustechtips.com/topic/1318195-first-build-help/
