First PC Build
Go to solution Solved by AnirbanG007,
33 minutes ago, Askabeh said:
Hello,
I'm live in Indonesia, trying to build my first PC
I want to build a budget pc for architecture software (autoCAD 2019, Sketchup 2019, Lumion 9 or 10, Photoshop, Premiere, and another office software - without Games)
I do research some parts :
- Ryzen 5 2600 processor
- Asrock B450 pro4 motherboard
- Gigabyte Geforce GTX 1650 super GPU
I need some recommendation for best budget version of :
- PSU that compatible with those parts
- Case with good air flow
I need to know also if there's any better choice for 3 parts that i've research? Maybe a cheaper part for better performance
My main consideration of this pc build is performance and speed for 3D designing and 3D rendering (don't care about looks) - Budget under $US 1000
Thank you
For PSU, I'd recommend the Corsair CX500, should be excellent for your build, and leaving some headroom for future upgrade. You could go for a 3600 instead of a 2600 if you have the budget for it otherwise it's completely fine. For RAM, I'd suggest getting 2 sticks of 8 gb each at 3000 MHz for 2600, or 3200/3600 MHz (depending on budget) if you can go for r5 3600.
For storage, get a 250/500 gb SN550 SSD from Western Digital as boot drie, and an HDD for storage depending on your requirements.
Hello,
Thank you
https://linustechtips.com/topic/1318068-first-pc-build/
Hello,
Thank you
Attention is what makes life meaningful.
Also, please quote me for a reply. 🙂
https://linustechtips.com/topic/1318068-first-pc-build/#findComment-14583054
27 minutes ago, CrownieOG said:
For the PSU i would look in the psu tier list , regarding the case i would recommend the Phanteks P300A (would need 1 more fan to perform perfectly) or the P360A or the Silverstone Fara R1 (would need 1 more fan to perform perfectly)
Thank you for your recommendation, i will check that in my country
https://linustechtips.com/topic/1318068-first-pc-build/#findComment-14583081
Thank you for the extra information, i can finish my build now i think, i will check the price in my country
https://linustechtips.com/topic/1318068-first-pc-build/#findComment-14583083
It would better to go with a Ryzen 5 3600 if you can as it is the best bang for the buck processor right now in the mid-tier segment and talking about the PSU going with any 500-650W reputed 80+ bronze (Gold is better) PSU would be more than enough even if you decide to upgrade in the future. and coming to the graphics card, if you able to find the 1650 super at MSRP, grab the deal before its gone and is its over priced like most of the Graphic cards right now, i would recommend you to wait.......
Hope that helps.................:)
Ryzen 5 2400G -B450M DS3H Motherboard (Gigabyte) - 16GB RAM (CL 16, 3000MHz) - 240GB SSD (Kingston) - 1TB HDD(Seagate) - 450W PSU (Corsair)
https://linustechtips.com/topic/1318068-first-pc-build/#findComment-14583141
