Hey guys
So apparently it is a known issue that running OBS with dual monitors with different refresh rates will result in laggy recordings/streams if the OBS window is not running on the same monitor as the one you are trying to capture/stream.
My main display is 165hz, secondary is 60hz. When OBS window is on secondary screen the recording/stream is extremely choppy. If I drag the OBS window over to my main display the problem immediately disappears.
Would running the secondary monitor from a second seperate GPU (like a GT710) solve the issue?
Setup is as follows:
Aorus B450 Pro
Ryzen 5 3600
RTX 2070 super
16gb 3200mhz ram.
Any help will be greatly appreciated.
https://linustechtips.com/topic/1317452-dual-monitors-obs-dropped-frames/
