Budget (including currency): 450 euros
Country: Montenegro
Games, programs or workloads that it will be used for: Games: CS GO, Apex Legends, Rocket League, Rainbow Six Siege and for school bcs aps really laggy on this that i have now.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Well i found this:
RX 570 4gb (used) - 85 euros
Ryzen 5 2600 (new) - 155 euros
B450M DS3H (new) - 72 euros
8GB ram (new) - 44 euros (will upgrade in the future)
SeaSonic S12III 550w (new) - 52 euros
Case with good airflow and beautiful look (4 fans) (new) - 45 euros
I have monitor 60hz, 900p so i believe i will play on 900p,
And my pc now is 15 years old, that is why i want to upgrade it,
And I will buy it after 1-2 year bcs for now i can stay with this and I will get pc(as a gift) that photograph used it for editing photos, I believe i can play cs go on it but I will continue saving for this one or something better, whatever u find.
Don't tell me about R5 1600 AF, there are not 1600 AF cpus here.
https://linustechtips.com/topic/1316260-help-with-the-build/
Country: Montenegro
10400f is likely a better deal than a 2600 if they are the same price, or you could just upgrade to a 3600.
https://linustechtips.com/topic/1316260-help-with-the-build/#findComment-14569450
10400f's here are about 180-200 euros, the cheapest motherboard for 10th gen intel cpus with 4 ram slots is: GIGABYTE B460M DS3H REV 1.0 for 93 euros, and as i asked a lot ofr people they say intel stock coolers sucks so i will need to buy a cooler for it: about 15-30 euros, the smallest price for it and these motherboards here come without updated bios so i will need to pay 10 euros more for updated bios so 3600 is not an option and it is priced here as 200+ euros...
https://linustechtips.com/topic/1316260-help-with-the-build/#findComment-14569466
I see, in some countries intel is cheaper than amd so just wanted to check. Seems good then.
https://linustechtips.com/topic/1316260-help-with-the-build/#findComment-14569470
And will my build be good to buy it after 1, 2 or maybe 3 years, bcs i don't need it now bcs i will get pc for like 1-2 months, but idk if these items will be available so i will maybe again post here topic to ask.
https://linustechtips.com/topic/1316260-help-with-the-build/#findComment-14569473
What about a used 16 or 2600? Or a 3100 (if you can find one).
My primary system: Core I7 10700k, 32 gb Trident Z RGB ram@3200mhz, EVGA GTX 970 SSC (will upgrade), NZXT N7 Z490 motherboard (Black), Samsung 970 Evo plus 1TB SSD, NZXT C850 PSU, Hyper 212 EVO cooler (getting new water cooler soon), NZXT H510i case.
My secondary system: Core I7 4820k, 16 gb quad channel 1600mhz ram, GTX 780 reference, Asus PX79LE, SK Hynix GOLD s31 500gb SSD, some 10 yr old Cooler Master 750w psu, Hyper 212, old Cooler Master case.
Laptop: Lenovo l380 yoga I5 8250u, 8gb ram, 256gb ssd storage)
https://linustechtips.com/topic/1316260-help-with-the-build/#findComment-14569474
And guys, my friend is building his first pc now(me too), he asked me what parts can he get for 320 euros without case, Idk what to tell him, is this good what i found for him:
GTX 750 Ti, used - 45 euros
Ryzen 5 2600, used - 110 euros (now i saw they selling them used so i will tell him to get this)
B450M-HDV R4.0, new - 68 euros
SeaSonic SS-500GB 500w, new - 48 euros
Ram 1x8GB G.SKILL F4-3200C16S-8GIS (3200MHz), new - 42 euros
https://linustechtips.com/topic/1316260-help-with-the-build/#findComment-14569512
He should spend less on the cpu and more on the GPU.
https://linustechtips.com/topic/1316260-help-with-the-build/#findComment-14569527
12 minutes ago, Jovo said:
Yeah but when he get money he will buy rx 570 like me, he just need something to play cs go with me or maybe rocket league idk what he wants to play 🙂
Ok that works then.
https://linustechtips.com/topic/1316260-help-with-the-build/#findComment-14569554
13 years old is a fine age to build a pc. Probably best to check with your parent(s) though.
https://linustechtips.com/topic/1316260-help-with-the-build/#findComment-14569573
Should I go with B450M DS3H for ~90 euros or with B450M PRO4-F for ~84 euros? Becouse, idk, DS3H has 4 ram slots, PRO4-F has 4 ram slots, DS3H supports 1st gen and 2nd gen ryzen cpus, PRO4-F supports 1st gen and 2nd gen ryzen cpus, is it something in quality or what?
https://linustechtips.com/topic/1316260-help-with-the-build/#findComment-14569621
