I change my mind or I should not?
Games, programs or workloads that it will be used for: 1080p 240hz Gaming, Streaming and secondary machine.
i7 10700k = $362
Scythe Fuma 2 = $55
Z590 Aorus Pro Ax = $333
(2x16gb) Xpg Spectrix D60g 3200mhz = $172
RTX 3060 Ti = $ unknown
Sx8200 Pro 1Tb = $124
Cooler master v750 gold v2 = $112
Phanteks P360A = $76
Total = $1234
i9 10850k is $398 and need a better cooler. Should or shouldn't?
https://linustechtips.com/topic/1315118-new-build-help/
Depends if you need the extra cores & threads. I'd say just stick with the i7.
I'd change your RAM to a cheaper option. 2666MHz is already good enough for Intel, since higher memory speeds don't benefit Intel chips as much as they do for AMD Ryzen chips.
Switch your SSD to a WD Blue SN550 1TB. The controller and NAND in the SX8200 SSD you listed was recently switched to some slower option.
Get a Corsair RM750 PSU. It should be cheaper and perform the same with the PSU you listed.
Everything else looks good for me.
→  Kindly quote or mention me if you would like a reply back.
<famous quote>
https://linustechtips.com/topic/1315118-new-build-help/#findComment-14559322
