I'm looking to upgrade my CPU to get better FPS in CSGO. I'm currently on a i5-9600K, 64GB RAM, and a GTX 1080, so I'm looking to upgrade my CPU most likely. I want minimum 150FPS consistently with low settings 1080p, even on the laggier maps; sometimes my FPS dips low enough that it's below the refresh rate of my monitor (especially when I also have a lot of other stuff open like a twitch stream or music or whatever), which I want to avoid at all costs. Would getting an i7-9700K be an effective way to reach this goal, or is it too little of an upgrade from my current setup? I'd like to spend as little money as possible on this. I use this PC for literally nothing else, so don't worry about any other use cases.
FANBOY OF: PowerColor, be quiet!, Transcend, G.Skill, Phanteks
FORMERLY FANBOY OF: A-Data, Corsair, Nvidia
DEVELOPING FANBOY OF: AMD (GPUS), Intel (CPUs), ASRock
https://linustechtips.com/topic/1314490-cpu-upgrade-advice/
Honestly a 9700k would make some difference but I'd really say not that much. Overclocking your 1080 and the 9600k would give maybe even a bigger bump than just upgrading to the 9700k (unless your CPU cooler is crap of course)
https://linustechtips.com/topic/1314490-cpu-upgrade-advice/#findComment-14554269
a 1080 and 9600K should easily hit 150+ FPS constantly, my old ryzen 5 1400 and gtx 1050 got 120 - 150 FPS
Sounds like there may be something wrong with your PC
geometry is hard
b550 > x570
https://linustechtips.com/topic/1314490-cpu-upgrade-advice/#findComment-14555689
To be clear, this only really happens on maps like Nuke or Vertigo, laggier maps, when I'm doing stuff like watching twitch streams at the same time on my second monitor, and especially when I'm next to a smoke. But, if this is still unusual, do you have any advice on what I should be looking at to fix this?
I don't have an OC motherboard, unfortunately, and I have an ITX build so I don't know if I'm comfortable with OCing, especially since I don't really know what I'm doing.
https://linustechtips.com/topic/1314490-cpu-upgrade-advice/#findComment-14555908
  • 4 weeks later...
Well that is unfortunate but OCing is actually quite painless and simple.
https://linustechtips.com/topic/1314490-cpu-upgrade-advice/#findComment-14619818
