NZXT Kraken x63 Pump RGB Led Problem
burialzz
Hey, I've been dealing with this issue since i built PC with NZXT Kraken x63. All cables are connected correctly as it's written in Manual of installation. The AIO is working really well on OC 8700k,it can also be detected in NZXT Cam with The strip of NZXT H510i. I Can change everything except pump RGB Light (Circle/Led) and its only visible in the one corner,can't even light up NZXT Logo (Check the real image).I've tried different usb ports and other sata connectors but still same. Am i doing something wrong or it has dead Led on pump? Should i contact the seller? Thanks.
  • 1 year later...
Hello!
I was wondering if you'd found the solution to this since I've got the very same problem and you're the only other person I could find.
Thank You!
