PC Help debate
Solved by WaitWhaaaaat,
2 hours ago, BossmanReeYT said:I have a build that is CPU bottlenecked I have an i3-10100 and 2070. Should I get a new PC or just upgrade my processor
Upgrade to i5 10600k. This processor should work fine with 2070. This cpu have similar price to R5 3600, so this is the cheapest option. Going with ryzen will require switching mobo so you need to double amount of money that needs to be spend on that.
