Hi, I'm having issue with my PC hoping someone can help me out.
My PC was running fine with 5600X
RTX 3060Ti
Mobo: X570 Tomahawk WiFi
Latest BIOS
I changed GPU this morning and it stopped booting
To get it booted after that I had to short the power pins. Now it boots fine with power switch
Since then It boots but I keep getting CPU debug light.
As soon as I press the power button, CPU debug light is on.
I've reflashed BIOS
Cleared CMOS
But same issue
Any help would be great
Thx
https://linustechtips.com/topic/1313612-cpu-debug-led/
Just a quick update
I've taken everything out of the mobo to flash the new BIOS and while it's flashing the new BIOS, CPU debug light is still on.
Update 2:
So done bios flash again without CPU,
Plugged in CPU only and debug led changed to DRAM
When I plugged in dram, it changes back to CPU again.
https://linustechtips.com/topic/1313612-cpu-debug-led/#findComment-14546530
