Budget (including currency): MYR
Country:  MALAYSIA
Games, programs or workloads that it will be used for:  PUBG, ADOBE PREMIERE, AFTER EFFECTS, LIGHTROOM, PHOTOSHOP
Other details
Current PC parts
ASUS 570x Tuf Gaming Wifi
Ryzen 3700x
Asus RTX  2070 Zotac
32gb Kit LPX Vengence Corsair + 16gb Kit LPX Vengence Corsair
Corsair 750w Gold Plus
Coolermaster  ML360 V2 ARGB AIO
Coolermaster case MB 350 P
please suggest what to retain and ITX parts and case
Thank you
https://linustechtips.com/topic/1313487-convert-atx-to-itx/
I I'm assuming the ram is a 2x16 and a 2x8 kit?
You would need to only use 2 sticks of ram.
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1313487-convert-atx-to-itx/#findComment-14545327
Oh ya forgot about the stick.  hmm.   Well if like that,  i need to go full RAM.
any ITX that supports 128gb of RAM ?
https://linustechtips.com/topic/1313487-convert-atx-to-itx/#findComment-14545348
All do, you just need it in a 2x64gb stick.
Bios database
prior build:
https://linustechtips.com/topic/1313487-convert-atx-to-itx/#findComment-14545361
3 hours ago, CircleTech said:
As of 2021, there are no consumer motherboard that support 128GB of RAM.
You would have to buy an Asrock Rack ITX motherboard and stuff two 64GB sticks of ECC Registered DDR4 into them, which would be ridiculusly expensive.
Thank you bro. . I am totally blurred about this stuff
https://linustechtips.com/topic/1313487-convert-atx-to-itx/#findComment-14545738
