I recently bought a 2tb hdd because I only have a 500hdd and every time I connect the 2tb, my games start lagging and my 500gb (main drive aka C:) is stuck at 0% on read in task manager, does anyone know what the issue is and how to fix it (when I disconnect the 2tb drive everything goes back to normal and my 500gb starts reading again)
https://linustechtips.com/topic/1313139-problem-with-new-hdd/
You sure the disk is online? check under disk management 😕
or try this :
  1. Go to Start, type power options and hit Enter.
  2. Click on Change plan settings.
  3. Click on Change advanced power settings and select Hard drive.
  4. At the turn off hard disk after, select maximum time to prevent the hard drive from powering down.
https://linustechtips.com/topic/1313139-problem-with-new-hdd/#findComment-14542331
Check bios for any raid configurations
https://linustechtips.com/topic/1313139-problem-with-new-hdd/#findComment-14542354
or try this :
It doesn’t turn off, everytime I connect the 2th my games start lagging
https://linustechtips.com/topic/1313139-problem-with-new-hdd/#findComment-14543116
4 hours ago, Elo Gaming said:
Search disk management in windows and go to create and format hard disk partitions. Take a screenshot of that window and send it.
Ok I’ll do that when I’m able to get on my pc , also I have the 2tb disconnected, should I connect it back I only have the 500gb connected
https://linustechtips.com/topic/1313139-problem-with-new-hdd/#findComment-14547078
