Hi, 3 months ago i built a gaming pc
Specs:
Ryzen 7 3700x stock cooler
8gb ram ddr4 corsair vengence 3200mhz
1th hdd
 msi b450 tomahawk max
radeon 5500xt gigabyte oc
650w psu from corsair
After a few weeks after the build there was no more freezes but now 2 months after i get random freezes when playing a youtube video, changing tab, launching a game( at this point
i crash)
It's very strange because it started happening now. Before i had no problem, i played demanding games in ultra and no freeze/crash but now i can even use it.
Any idea why it's haappening ?
*NOTE*
 I also noticed that when my pc freeze i see the VRAM clock speed in my gpu driver benchmark go up very fast when it's freezed.
https://linustechtips.com/topic/1312892-build-keep-freezing-randomly/
Did you do anything specific to the computer before you got the freezing issue? Did you install, uninstall software, update drivers, anything?
Generally if a computer has worked just fine and has suddenly stopped all of a sudden, it is rarely due to a hardware issue. Most likely drivers-related. My recommendation would be to do a System Restore to a date before the freezing began.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
Specs:
1th hdd
i crash)
*NOTE*
Have you updated your AMD Ryzen chipset drivers? That fixed my micro-stutters
hi, im renata bliss and am ur freestyle dance teacher
I re installed windows because of this but i haven't changed any driver
