Base Frequency Boost?
Go to solution Solved by RAS_3885,
It's overclocking, presumably for non-k series CPUs by adjusting the base clock frequency instead of the multiplier. For reference, ASRock's page on it.
https://www.asrock.com/microsite/2020BFB/
Unless you know what you're doing and have adequate cooling to support I'd leave it alone.
I was looking in my BIOS to figure out why my RAM was running at 2400mhz and found this option. Should I enable it and if so, what should I set it to? It has a lot of options from 65w to 125w.
ASRock B460M Pro4
i5-10400F
Sapphire RX 5500 XT
Be Quiet! 600w PSU
16GB 3200 HyperX Fury
https://linustechtips.com/topic/1312109-base-frequency-boost/
The limit of your ram is 2666 on that motherboard with that CPU, so you can manually set that.
As for base frequency boost, I think that might be one of the CPU boosting cheats that got implemented to speed up locked intel CPUs (I don't think it works that well)
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1312109-base-frequency-boost/#findComment-14534370
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
https://linustechtips.com/topic/1312109-base-frequency-boost/#findComment-14534375
I have a stock cooler and 1 case fan for cooling so I don't think my cooling would be able to handle it. I guess I'll leave it off and maybe change it once I get better cooling
https://linustechtips.com/topic/1312109-base-frequency-boost/#findComment-14534378
I'd just leave it alone regardless of cooling. Base clock OC can get strange as many things run based off the base clock frequency and it can have unintended side effects.
https://linustechtips.com/topic/1312109-base-frequency-boost/#findComment-14534379
