I have a xfx radeon rx 570 gb gpu (other specs Ryzen 5 1600 processor, asrock b450m pro4 micro atx motherboard, 2x4gb patriot viper 4 ram sticks, pny cs900 500gb ssd, xf radeon rx 570 xx 8b gpu, and a thermaltake 430w 80+ white psu. also the case is a thermaltake versa) i dropped my pc not to long ago, and when i went to pick it up everything looked fine so i plugged everything back in and everything looked like it was running fine the fans were spinning everything was on but when i turned on the tv (didnt have a monitor just a small tv) it said no signal i tried many other hdmi's and 2 other tv's and still no signal anyone tell me why this is happening pls. (also the light on the gpu stays blue and fans on the gpu spin for a while then stop)
https://linustechtips.com/topic/1311792-no-signal/
