I decided to do a manual overclock of my 8700k yesterday. I dialed in all my settings and ran a few stress tests, finished off with running Prime95 for an hour to check for instabilities. Everything went fine. But then today started to play Destiny 2 and my main screen kept on going black then coming back (computer still running almost like the source was being changed). I changed over my main screen so I was playing on my secondary and that one was fine but the other continued to go blank then come back on again.
I checked all the cables and everything was fine, so I thought I would remove the OC that I did. That was about 12 hours ago now and I have had no problems with my screen.
Does anyone have any suggestions that would be great. I have had an auto OC on this before and it was fine.
Specs:
8700k
Asus Maximus XI Hero Z390
Fractal Design 360 AIO cooler
RTX 2070
OC:
5Ghz
1.350 Volts
XMP1
https://linustechtips.com/topic/1311482-overclocking-problem-please-help/
That doesn't really sound like a CPU overclock issue, although that could manifest in a lot of different ways.
What's your power supply?
Are your graphics drivers up to date?
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
