1. Budget & Location
location is Israel.
the parts will be from amazon- maybe just the case will be from my country
budget is 2000$
2. Aim
basic use- web, watching content,
open a excel sheets, remote connection to my work place.
lite video and photo editing
and sometimes gaming- not all the time but i want the option to game.
i know that thy graphics card price a high so maybe i can buy something simple and in the future i would like to upgrade
3. Monitors
2K display with 60 refresh rate
4. Peripherals
i need a place on the itx case for 3.5 Hard Disk
case that i liked is Cooler Master NR200-  (i would like a silent case)
2TB NVME
32 Giga RAM
5. Why are you upgrading?
New Computer
thanks in advance!
https://linustechtips.com/topic/1309666-mini-itx-build/
location is Israel.
there is no specific budget.
2. Aim
basic use- web, watching content, work and sometime gaming- not all the time but i want the option to game.
3. Monitors
4. Peripherals
New Computer
thanks in advance!
what is your budget? Are you okay ordering from the UK (the us has like nothing in stock)
Also what is your "work"
geometry is hard
b550 > x570
https://linustechtips.com/topic/1309666-mini-itx-build/#findComment-14514677
37 minutes ago, FighterB said:
thanks for the replay!
the budget is roughly  2000$
I think it shouldn't  be a problem to order from the UK
and work is open a excel sheets, remote connection to my work place.
Please quote us next time, I had no idea that you responded.
location is Israel.
budget is 2000$
2. Aim
3. Monitors
4. Peripherals
2TB NVME
32 Giga RAM
New Computer
thanks in advance!
geometry is hard
b550 > x570
https://linustechtips.com/topic/1309666-mini-itx-build/#findComment-14514862
10 minutes ago, Downkey said:
thanks for the build.
but it's not a mini itx build.
and i mentioned that i want 32 giga
2 TB NVME
and 3.5 disk i have from my old pc
https://linustechtips.com/topic/1309666-mini-itx-build/#findComment-14514885
2 TB NVME
I FORGOT IM SO SORRY LOL
am making a new one rn
geometry is hard
b550 > x570
https://linustechtips.com/topic/1309666-mini-itx-build/#findComment-14514886
2 TB NVME
geometry is hard
b550 > x570
https://linustechtips.com/topic/1309666-mini-itx-build/#findComment-14514901
I like the PC to be as small as possible, so here's a 5.9L build. NR200 is 18L for reference.
CPU cooler won't be too good, lemme check if a harddrive can fit, it might not be able to. In that case go for the Ncase M1 I'd say. Do you absolutely need the drive though? Or would transferring the data on it (if there is any) to a large M.2 work.
Current System: Ryzen 7 3700X, Noctua NH L12 Ghost S1 Edition, 32GB DDR4 @ 3200MHz, MAG B550i Gaming Edge, 1TB WD SN550 NVME, SF750, RTX 3080 Founders Edition, Louqe Ghost S1
https://linustechtips.com/topic/1309666-mini-itx-build/#findComment-14514927
Location is UK that way stuff is actually instock-ish so the pricing works better.
good build, although this is $350 over budget
geometry is hard
b550 > x570
https://linustechtips.com/topic/1309666-mini-itx-build/#findComment-14514950
Fixed, used 3060 Ti FE (still goes in stock for $399 quite frequently) and that keeps it under 2000 USD
https://linustechtips.com/topic/1309666-mini-itx-build/#findComment-14514970
Thank you for the build!
regarding the hard disk.
the propose is that i have a 12TB Disk with movies and series and i save them in the disk.
so yes. its important for me.
regarding the case size.
until now i used the NZXT H710I so any case will be small for me lol
https://linustechtips.com/topic/1309666-mini-itx-build/#findComment-14515066
Wow! I'd get an Ncase M1 then probably, that can fit a 3.5 inch SSD I believe.
https://linustechtips.com/topic/1309666-mini-itx-build/#findComment-14515151
