Please help!!
 specs:
Ryzen 5 3600
AMD Radeon rx 5500xt
corsair cv550 psu
B450 aorus elite v2
team group gx2 512gb ssd
corsair vengeance 3600mhz16gb ram
My pc used to work perfectly fine before I had a problem where it would restart everytime I would login, I then reinstalled windows onto it and it worked fine, I left it on a clean install of windows for around 5 minutes while I took out the trash and came back to it showing a black screen, mnk were both off yet the pc was on, it wasnt in sleep mode either, I attempted to restart it multiple times and nothing worked, I assumed it was the motherboard and shipped it in with the RMA process. I just got it back and the pc wont post, sometimes it will boot into bios and it will say that the bios has been updated and reset and everytime I press “ok” my screen goes black and mnk both turn off, my motherboard then shows a red led on dram. Most of the time I cant even get it to post, sometimes my keyboard is on but my mouse only comes on for the short time I enter bios my pc was only working for a few weeks before these problems surfaced, motherboard has newest bios installed, I wasnt able to install the drivers for my graphics card however as I had just installed a fresh install of windows, im willing to answer any and all questions, please help, im 16 and I bought this pc with my own money and I just want it to work again.
https://linustechtips.com/topic/1309511-please-help/
Yes! I have two corsair vengeance 8gb sticks and a ripjaws v 16gb stick, ive tried every single one of them in each dimm slot to no avail, I also have two psu’s I have a corsair cv550 and a cx450 both are brand new and all of this leads to the same outcome sadly😔 im thinking it may be a cpu problem which is probably best case scenario as I have a warranty on every part except my gpu so I could just do the AMD RMA for my cpu but I want to see if anyone else would know if its right.
https://linustechtips.com/topic/1309511-please-help/#findComment-14513545
