ISSUE WITH VISUAL STUDIO
Solved by Nurgster,
It looks like you may have deleted the uninstall files for the VC runtime - have you run any non-MS disk cleanup utilities on that machine? (the option these have to remove uninstallers will break things like this). You might have some luck if you download and reinstall the VC runtimes, then do the uninstall, which can be downloaded from:
VC2010
- https://www.microsoft.com/en-gb/download/details.aspx?id=14632 (x64)
- https://www.microsoft.com/en-gb/download/details.aspx?id=5555 (x86)
VC2008
- https://www.microsoft.com/en-gb/download/details.aspx?id=15336 (x64)
- https://www.microsoft.com/en-gb/download/details.aspx?id=29 (x86)
