So recently I have been having issues on league of legends where if I have it displayed on my primary display once I tab in and out I drop fps from 200+ to 80 and if I do borderless it stays at 80fps but if its windowed the fps is remains at 200+. Now if I set the display that league of legends in displayed on as my secondary display all the fps issues are fixed  but once I change it back as my primary display the issues return. I have no real clue on how to fix this. I have already done a clean install of drivers for gpu, uninstalled the game and deleted the files and then reinstall, rolled back windows and gpu to older updates where it worked fine but no dice I don't know what else to do
https://linustechtips.com/topic/1308775-fps-issues/
I have already tried the repair option, as a last resort i've even reinstalled windows no dice lol
both monitors i'm using are both 60hz and and v-sync is never an issue and is also never on  just a weird issue on this one game if its played on my primary display every other game works fine
the pc specs are
CPU:ryzen 5 1600
GPU:gtx 1070
MB: B450 Pro Carbon
16 GB Corsair vengeance  3200mhz
750 watt psu
https://linustechtips.com/topic/1308775-fps-issues/#findComment-14510305
