So I recently purchased a Fantech cg71 and I was wondering if the RGB cables need to be plugged into the MOBO for them to work. I have plugged in all the front panel cables including the sata power however because my motherboard doesn't support it I can't plug in my RGB and GDV cable
https://linustechtips.com/topic/1307913-case-rgb-issue/
I'm not entirely sure but I have the same connector on my case and it's to control the lights on the case and it doesn't fit into my mobo either. I think you're supposed to use some sort of RGB controller or adapter to plug that in. I don't have one so I just change RGB via a button on my case. The lights themselves work though. Because the one you're holding in the picture is a female connector with 4(?) holes in it right?
GPU: RTX 2080 Super        Keyboard: Corsair K70 MK.2 RGB
CPU: i7-9700K        MouseLogitech G PRO Wireless
RAM: 16 GB Corsair Vengance PRO                                                         Headset: Corsair HS70 PRO Wireless
PSU: CX650F        MousepadCorsair MM500 Extended 3XL
MOBO: Asus Prime Z390-A        ControllerDualSense 5
Case: Lian Li Lancool II        CameraCanon EOS M50
Monitor: Samsung Odyssey G5        CoolingCorsair H100i Platinum
The white Rabbit        MicrophoneTrust GXT 252+
https://linustechtips.com/topic/1307913-case-rgb-issue/#findComment-14500284
