Im planning on adding case fans. Because my case is from be quiet I prefer their case fans but I dont know wether the shadow wings 3, are the exra money worth or should I go with the pure wings 2? Is it a good idea to buy used fans? Does PWM or high speed fans make any noticable (cooling) performacne difference?
https://linustechtips.com/topic/1307387-case-fans/
I'd get pwm fans so you can control their speed, and conversely their noise.
https://linustechtips.com/topic/1307387-case-fans/#findComment-14496442
you can get whatever fans, just because your case is bequiet doesnt mean you have to use bequiet fans, some arctic p12's/p14's would be perfect as case fans.
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1307387-case-fans/#findComment-14496452
