I recently got my custom PC from CyberPower.
CPU: Ryzen 9 5950X
CPU Cooler: Enermax ETS-T50 AXE (Fans: BLACK ENERMAX TWISTER BEARING PWM FANS, push pull)
Motherboard: Asus TUF GAMING X570-PLUS (WI-FI)
Memory: 4x16 GSkill Trident Z RGB
GPU: MSI GeForce RTX 3090 24GB GAMING X TRIO
Case: Thermaltake View 37 (1 Exhaust top back, 2 intake at the front)
Monitor is 1440p
So far, the PC has shut off 3 times, which I believe is due to too high thermals. Right now, with a twitch stream in the background, I'm running at 49-50C Tdie. When I was running GTA V at Max settings, I was pushing 100C at times on the CPU Tdie.
According to the TDPs, the CPU Cooler should be capable of cooling the 5950x, but based on what I've seen I don't think it's doing all that good of a job. Did I make a mistake in my CPU Cooler? Or maybe case, in terms of air flow?
https://linustechtips.com/topic/1307311-thermal-issues/
