Hello
         I need help for my new build i got a few days ago my ram speed isn't at its advertised speed, I ENABLE XMP and its sets one part of my RAM frequency to 3200 but the other part still says 2133. My build is a APU build so my memory speed is very important i have dual channel G.Skill ram. I have provided a video of me trying to get 3200mhz please help me if you can and here is my build: https://pcpartpicker.com/user/txhh/saved/DMr2Vn
https://linustechtips.com/topic/1306850-memory-speed/
Welcome!
Try moving the RAM modules  to the A2 and B2 slots. While for whatever reason the online manual for your motherboard doesn't show Picasso CPUs (which the 3400G is), the ones it DOES list appear to show that when using two sticks they need to be in the A2/B2 config for higher speeds.
I also found an old thread here that talks about the B450M, and it did have a chart for Picasso CPUs which supports this as well.
See if that works.
As a side note, your parts list is set to private so I can't see what exact memory kit you have, but you should cross-reference your motherboard's QVL list if moving to the other DIMM slots doesn't work.
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
https://linustechtips.com/topic/1306850-memory-speed/#findComment-14492322
22 hours ago, TK_EXE said:
tysm it works :))))))))
Awesome!
BTW, make sure you quote folks you reply to, otherwise they may not know you've responded to them.
https://linustechtips.com/topic/1306850-memory-speed/#findComment-14495341
