whats some good red and black good looking ram that is good for being water cooled i want to water cool my hole system.
If you're going to watercool your ram, just get one with a black pcb.You're going to have to remove the heat-spreader anyway I believe.
https://linustechtips.com/topic/130666-ram-water-cooling/#findComment-1739340
