Audio through console and PC
Hi guys,
When I was using the optical cable and USB through my Astro A50's, I was able to listen my game on the Xbox one and have sound on my PC with the microphone. Now the series X does not have a optical cable, I cannot do this and have to switch one to the other. Is there a fix around having sound on both? I have tried a audio extractor and and makes bad echo and static noises
https://linustechtips.com/topic/1305784-audio-through-console-and-pc/
  • 2 weeks later...
On 2/14/2021 at 2:48 PM, MA1 said:
Hi guys,
What about a basic mixer to have both inputs into and an export out.
On 2/14/2021 at 9:48 AM, MA1 said:
Hi guys,
you'll have to check to see if this works with the xbox series x, but the topping d10 can both turn usb audio into a digital optical signal and into an analog coaxial signal.
