Help would be appreciated!
Go to solution Solved by SAV1OUR,
Awesome, Yeah i had dismissed water cooling all together for sake of space, but i might actually do that! But would the 212 Evo fit if i go that route instead?
I already bought almost everything but here is the rest of my build.
CPU- i7 4770k
MB-  Gigabyte Z87 Sniper M5 Micro ATX
Ram- ADATA 16gb 1600
Storage- Samsung 840 Evo 250gb
GPU- EVGA GTX 770 4gb
yep it will fit just fine
So for my first build I am going  to use the bit of help.
So I wanted to get the Be Quiet Shadow Rock 2 , but it is slightly difficult to find and since i have prime i was wondering if this is a better option.
http://www.amazon.com/Noctua-NH-U14S-Sockets-Heatpipe-Cooling/dp/B00C9FLSLY/ref=sr_1_3?s=electronics&ie=UTF8&qid=1395535378&sr=1-3&keywords=noctua
My case is the BitFenix Mini-ITX case.
or should i go with something like the coolermaster hyper 212 evo?
https://linustechtips.com/topic/130555-help-would-be-appreciated/
the noctua is a fine, you could also get something like a h100i and line it with quite fans
Specs
uh, would i be able to cram that in there? A AIO closed looped cooler would be nice but im a bit worried about space.
what case is it specifically? bitfenix have allot of cases
Specs
Whoops my bad i forgot the link.
http://www.amazon.com/gp/product/B00G483C7A/ref=oh_details_o00_s00_i01?ie=UTF8&psc=1
Thanks for the help by the way!
ok this a phenom you could fit a h80 in it
http://ca.pcpartpicker.com/builds/by_part/bitfenix-case-bfcphm300kkxkkrp#h=34
Specs
CPU- i7 4770k
CPU- i7 4770k
Specs
