Okay so my new computer has a i5 10 gen 4.1Ghz and 16gb ddr4 but im only getting 40fps in minecraft ???
I have a really bad 1 gb ddr3 gpu but with CSGO and half life 2 are only using about 10% of my cpu and ram ???????
so i have no clue whats going on but if anyone has some tips pls help.
https://linustechtips.com/topic/1305405-i-need-help/
What GPU exactly? That's likely what's limiting you.
F@H
GPD Win 2
https://linustechtips.com/topic/1305405-i-need-help/#findComment-14480896
1 minute ago, ivvy said:
its worse its a nvidia geforce 210 1gb ddr3
but minecraft 40fps??
SO if i get a better gpu it will utilize more cpu and ram ???
The GT 210 is the worst GPU. it's even worse than a GT 710, I recommend you to get a good gpu, meanwhile you can remove the GT 210 and play on integrated graphics because it's better, I recommend you to get a second hand GTX 1650 if you have the money, if not, you can look for some of these cards:
- GTX 670
- GTX 680 (don't go for 690 as that gpu has 2 680 performing in sli so the performance will be bad)
- GTX 1050
- GTX 960
https://linustechtips.com/topic/1305405-i-need-help/#findComment-14480905
49 minutes ago, ivvy said:
My CPU doesn't have integrated graphics i dont think
It almost certainly does, but.. how about posting your full specs so we don't have to extract that info piece by piece from you to help you?
F@H
GPD Win 2
https://linustechtips.com/topic/1305405-i-need-help/#findComment-14480968
