15 minutes ago, OounknownoO said:
i need a laptop with a budget of 800 USD
I'll be using it for Adobe Illustrator and photoshop and maybe 3d modeling in the future (not very much like little things)
so i need help what specs are best within this buget for a laptop??
A Ryzen 4 or 6 core CPU like the R5 4600H
Ryzen 5000 laptops just launched, for 3D modeling though you'd be better off with a lot of VRAM potentially. Maybe get something that can use an external GPU.
If you aren't doing any gaming though you could just buy a laptop with a Ryzen APU and use the onboard graphics for most things.
https://www.bestbuy.com/site/asus-15-6-laptop-amd-ryzen-5-8gb-memory-nvidia-geforce-gtx-1650-512gb-ssd-fortress-gray/6409457.p?skuId=6409457&ref=212&loc=1&ref=212&loc=1&gclid=Cj0KCQiAyJOBBhDCARIsAJG2h5c0TG_gxtk8tNd5w_g_NgA2QSrZ9R55bKous593_iIkjP2tROcfW2QaApQOEALw_wcB&gclsrc=aw.ds
https://linustechtips.com/topic/1304922-need-a-recommendation/#findComment-14476691
