Just now, 3koperis said:
It is literally in my Post i7 6700 Intel based processor
Ha sorry, it's been a long day.
Task manager > performance tab > resource monitor (bottom right) > Memory
Here it'll show you how much of your RAM is hardware reserved. It's normal for some of it to be inaccessible to Windows but 2gb seems like a lot
https://linustechtips.com/topic/1304696-i-need-help-with-ram/#findComment-14474800
What do i need to see here?image.thumb.png.1790d2d31f11dc8054a91b7f0006d78e.png
https://linustechtips.com/topic/1304696-i-need-help-with-ram/#findComment-14474807
9 minutes ago, YourRandomForumGuy said:
Dunno much but maybe  2gb is for video ram
After some quick reading that is definitely a thing with integrated graphics, no dedicated vram so it takes from system mem. But what's weird is that it happened after a ram change, unless op just didn't notice before.
Try disabling the onboard graphics in your bios?
https://linustechtips.com/topic/1304696-i-need-help-with-ram/#findComment-14474828
51 minutes ago, 3koperis said:
yesterday i changed from single channel to dual channel ram now its 14 gb usable is this normal
GTX 1060 6GB
I7 6700 INTEL
128gb ssd
1tb
Windows 10 pro
Hyper x 8x2
H170A-x1
HyperX FURY 8GB 2666MHz
Go to task manager and see if you have another integrated graphics or gpu and if it is, then see the size of this gpu and try to minus that size from the total ram (i.e. 16gb - 2gb =14).
If it is the case , then it is totally normal.
https://linustechtips.com/topic/1304696-i-need-help-with-ram/#findComment-14474859
