Right now I'm working on designing and building a miniature house for my sister's pet hedgehog. Apparently they need to stay at a pretty warm temperature and I don't want to be putting big bulky heat lamps in the house. Instead I want to do radiant water heating in the floors. Is there any way I can repurpose a water cooling look to be a water heating loop instead? How can I do this if possible?
https://linustechtips.com/topic/1304293-quick-question-about-water-cooling-loop/
I don't think you would be able to produce enough heat to properly keep the area warm enough. Do it properly and use a heating lamp.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
Idk about the tubing radiating much heat to do flooring.
But you could make a rig and have it under load, plenty of heat that way.
Currently how I heat my room. Dumps lots of heat. But like mentioned, isn’t efficient.
You know, the air that goes through a radiator is not heated up by much, only a handful of K in most cases (after all coolant temps are usually ~10K over ambient). This is a terrible idea either wasting energy because you'd need to have your PC running on full blast 24/7 to have significant output.
Get a proper lamp.
Use the quote function when answering! Mark people directly if you want an answer from them!
