Cyberpunk 2077 fps issues
Carz728
I have a 3060 ti and a ryzen 7 3700x with 2400mhz memory. There are certain places on the map where I struggle for 50 fps at 1440p. Nothing changes the fps. I've tried changing to 1080p and low settings. I've tried dlss on every setting. Is this a cpu bottleneck?
I wouldn’t say so, more issues with the game. I don’t think they have been able to prefect the optimisation of the game yet. However I could be wrong.
Cheers
Upgrade your memory.
It may not solve the problem, but going from 2400 to 3600 can provide a high performance improvement.
elephants
Going from 2400 to 3600 can provide a high performance improvement.
Yeah I've been thinking of doing that. Would there be much of a difference at 1440p though
I also have a 3060 Ti, 3200Mhz and a R5 3600. I hit 60-70 with RT on and DLSS. 90-100+ without RT. Upgrade your memory 😉
“Appear weak when you are strong, and strong when you are weak.” - Sun Tzu, The Art of War #muricaparrotgang
Tier Lists and Specs List Below
Motherboard VRM tier list  -----  PSU tier list
React if you agree with me!
CPU: Ryzen 5 3600  |  CPU Cooler: Asus ROG STRIX LC240 White |  RAM: Crucial Ballistix RGB 16GB 3600 | Mobo: ASUS ROG STRIX B550-A  |  SSD: Inland m.2 NVMe SSD 256GB  |  HDD: Seagate 2TB 7200RPM |  GPU: RTX 3060 Ti FE  |  PSU: Seasonic SGX 650 |  Case: Lian Li o11 mini-W  |  Mouse: Razer Basilisk mercury |  Keyboard: Drop CTRL (Used. I did not spend $200 on a keyboard) |  Mouse Pad: Aura Mech Purple Storm  |  MonitorAsus TUF 24" IPS 144Hz 1080p
Most likely.
elephants
What resolution?
What resolution?
1080p, so my FPS will still be better on average.
