I have trouble with port forwarding on my ZTE ZXHN H267N router. In the Image below I have all the settings I have put into the port forwarding menu. I've put the LAN IP of my PC in the LAN Host IP field. I've tried checking if the port is forwarded via portforward.com's own app and many other sites and on every site it says that my router does not forward ports. What should I do?
https://linustechtips.com/topic/1303048-need-help-with-port-forwarding/
Have you also forwarded those ports in your OSes software firewall?
Main Rig:-
Server:-
3 minutes ago, DampRS said:
You mean one of these? or my public IP? I don't exactly understand as I'm not a native english speaker
Your Public IP
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
1 minute ago, DampRS said:
My public IP begins with a 31.223
Ok, so you're not behind CGNAT then so that's good.
Prior Build Log/PC:
Can you clarify which version of MC you're trying to host?
If its Java then its port 25565 TCP only (you currently have TCP & UDP selected).
If its Bedrock then its port 19132 UDP only,
Main Rig:-
Server:-
It's Java 1.16.4
It's Java 1.16.4
Try changing the rule to TCP only, its possible your router isn't triggering the port to be forwarded because its not seeing both the TCP & UDP trigger.
Notice it says "TCP And UDP" not "TCP Or UDP".
Main Rig:-
Server:-
It still doesn't forward ports.
Are you running Windows?
If yes then try turning the Firewall off entirely before running the server. The reason is to eliminate it as a possible cause.
Its also possible your ISP is blocking the ports at their end.
Main Rig:-
Server:-
The firewall is turned off so that just leaves my ISP?
Pretty much, the only other variable is the host IP address which should be the address of the machine the server is running on.
Main Rig:-
Server:-
