Beeps by system
Go to solution Solved by shone32,
As I found on internet repetitive short beeping can mean 3 things:
1. No Power
2. Loose Video Card
3. Short
Now, You can first check your graphics to see if it is connected properly (I recommend that you unplug it and plug it in again carefully) and try again.
If that doesn't help you can check to see if your PSU is good (try connecting friends PSU), but I don't think its PSU problem
And final thing if it's MOBO problem (VRM module problem - power, or short on board), you'll need to replace it.
Good luck fixing!
1. No Power
2. Loose Video Card
3. Short
Good luck fixing!
Athlon x4 840 @3.7Ghz MSI A68HM-E33 V2 8GB DDR3 1600MHZ SC GTX 750TI A400 120GB TOSHIBA 1TB MSI 200W
https://linustechtips.com/topic/1302974-beeps-by-system/#findComment-14460737
1. No Power
2. Loose Video Card
3. Short
Good luck fixing!
It seems it was g-card removed it and repluged and it works now thanks for solution.
https://linustechtips.com/topic/1302974-beeps-by-system/#findComment-14460794
