Morning Everyone.
So i started Fallout 76 yesterday for the first time.
So far seems like a good game but here's my question.
Is anyone else experiencing frames drops when Vsync is On?
With vsync locked at 60 i get these stutters that drop to low 50s.
When I turn vsync off im running anywhere from 80Fps to 120fps.
Running at 1080P
Specs below:
Ryzen 5 3600
RTX3070
16GB 3600MHZ
X470 Motherboard
Any help will be appreciate if there's any fix that might help.
Running game at Everything Ultra.
https://linustechtips.com/topic/1302575-fallout-76-stutter-and-fps-drops/
First of all, why running with vsync on? If you do, make sure to go to NVIDIA Control Panel, select the "Manage 3D settings" from the left column -> Find Fallout 76, click on the Power management mode drop down box and select "Prefer Maximum Performance
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
