Hey Guys,
I just transferred my system into a Lian Li O11-D Mini and switched from a cheap 530W Thermaltake PSU to a 650W FSP Dagger Pro.
After installing everything and filling my loop it booted right up and works fine so far.
The problem is, that for some reason I am getting pretty annoying background static now that I´ve changed Case and PSU and I´m suspecting grounding because the noise disappears when I touch Case or ground contacts in the outlet.
Does anybody know why that is and how to fix it?
Might just be that I´m noticing it because my PC is quiet now but either way it´s annoying😐
Full Specs if anyone is interested:
CPU: Ryzen 7 1700X @3.5GHZ
GPU: MSI GTX 1050Ti Gaming
RAM: 2x G.Skill Aegis 8GB DDR4 3000Mhz CL16
Mobo: MSI X370 Krait Gaming
PSU: FSP Dagger Pro 650W
Case: Lian Li O11-Dynamic Mini
Drives: Silicon Power 1TB M.2 NVMe SSD (OS Drive)
            Seagate Barracuda SSHD 1TB
            Cheap 60GB Amazon Sata SSD
Cooling: EK Supremacy EVO
              Alphacool 280mm Radiator (30mm thicc)
              Some EK Pump/Res combo they don´t produce anymore and I also can´t remember
              2x Thermaltake Riing 14
              4x EZDIY-FAB Dual Frame 120mm RGB PWM Fan
https://linustechtips.com/topic/1302426-background-noise/
