So i just wanted to test a cpu i was about to sell for the last time and when i was done checking it,i got the cpu out and put my cpu in.The pc is not working.It boots up does 4 or 3 beeps and gets stuck on this screen:
Is it the ram?Did i bent a socket pin? Well i tried switching rams and nothing happened.Now to make matters worse for anyone that wants to help the pc is a prebuilt.My dad bought it for me a few days ago and if he finds out its broken im f@#ked.
Cpu:i5 3470
Ram:DDR3 8gb 2x4 1600mhz
Motherboard:Hp 399A
Gpu: intel hd graphics
https://linustechtips.com/topic/1302334-help-im-really-screwd-up/
You need to get an exact count of the beeps, along with their length, to determine the POST code. See the table below:
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
https://support.hp.com/gb-en/document/c02222922
3 short beeps = Unable to start flashing (such as when missing a utility or BIOS image)
4 short beeps = Flashing failed (checksum error, corrupted image, etc.)
3 short beeps and 1 long beep = CPU configuration error or CPU type is not compatible
Is the CPU back in the correct way? Little triangles lined up?
Have you inspected the pins?
Is it definitely "clicked down" correctly?
If yes to all try doing a CMOS clear
Yep,i think they are bent.Check the picture too though cause im not sure.Is there any way to fix this?
They look fine to me.
The 'pins' are like little leaf springs, so as far as i can tell they all look fine.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
5 minutes ago, Shabba said:
hold on a sec, is every single one of them bent at the same angle? Did you perhaps try to clamp the CPU down while all of the pins weren't seated in the holes and bent the entire lot of them? Otherwise I'm not sure what I'm looking at here
Half the cpu's pins are bented one way and the other half on the other way.I only took pics of the 1 half so maybe thats whats confusing you
Dont bend anything!
Intel sockets look that way
31 minutes ago, Shabba said:
The motherboard is dead.The beeps it did indicated cpu problems and i cant get the motherboard out to try to fix it.Its a prebuilt and they've nailed the board to the case so i cant really do mutch.Wich is also the reason i couldn't get proper pictures.Im basically dead right now since i promised my dad i wouldn't swap the cpu again since he knew i would screw up the pins.Wish me luck!
I am not aware of a single OEM that does this, HP certainly doesn't. I'm sure you can get a replacement motherboard.
Desktop
Homelab
