HI last week i took out my gtx 1060 from the pc and I cleaned it
But after that i install new driver but after that all the games run at low FPS and with frieze all the time
There is a way to know what was the previous driver? (Because he runs well)
And mauby i done damage to it when i took it out?
https://linustechtips.com/topic/1302224-gtx-1060-problem/
On 2/5/2021 at 10:26 AM, LogicalDrm said:
-> Moved to Troubleshooting
Damage would show as artifacts and crashes, not really just fps issues. Try with older driver versions.
The problem in the end was that i forgot to plug the cpu power pin connector
https://linustechtips.com/topic/1302224-gtx-1060-problem/#findComment-14467283
