What would be a good AIO for this thing (Gigabyte 3070 Vision OC)?
Need some suggestions (idiot proof installation preferred!)
Also wouldn't it make sense to also put an AIO on the CPU then, on the same 'loop'?
And I suppose I would need another case then... but not sure, the inwin 301 has 2 huge openings in the bottom for fans, I could use those but idk if that's enough.
Oh also no NZXT, is out of the question I'm not installing CAM ever again (I guess that limits my options, huh)
Thanks in advance!
-Scott Manley, 2021
https://linustechtips.com/topic/1301770-rtx-3070-aio/
Thanks in advance!
I always hated the CAM software, its only helpful if you buy almost all you're parts from nzxt.
lttstore.com
https://linustechtips.com/topic/1301770-rtx-3070-aio/#findComment-14451256
