i know it is sound weird but im new to this audio world...
I have a old amplifier with 2 old speakers and they work great!
But i want to connect another 3 speakers, canter and two rears
My problem is that i don't know if after i connect the speakers i will get good stereo sound,
In the audio world can be a bottleneck like in the pc world ?
For example good amplifier and good speakers but the aux cable is not good?
And there is a special drivers that i need to install like Dolby atoms and stuff? or the the windows drivers are fine?
I will happy to know what can make my audio sound the best!
https://linustechtips.com/topic/1300653-audio-amplifier-problem/
It'll be fine. If you send stereo sound it'll play stereo.
Cables are cables. Get good ones, but don't spend a ton of money on them. All the multi-$100 cables are snake oil.
Dolby Atmos is an audio format that your receiver doesn't support and requires more than 5 speakers.
Your receiver seems to have optical in, so I'd go optical from your motherboard (if it has it) to the receiver.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
