Those are replacement cables that go directly to the PSU. They're only suitable for Corsair Type 4 cable compatible power supplies.
https://linustechtips.com/topic/1300299-braided-premium-cables/#findComment-14439402
13 minutes ago, venomx said:
Plug directly to the PSU. In order for them to work you will need to have a Corsair PSU suing the Type 4 cables already. If you have a Corsair PSU and you want to use these, you can see if yours does have the necessary cables by simply looking at the connectors on the PSU end. If it is written Type 4 on them then you can replace your cables with these.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/1300299-braided-premium-cables/#findComment-14439419
