i have my pc for a 1.5 year i think it was a new build last month i restarted the pc and no post + power button not responsive at all i held it for a 50 sec i just switch the psu off/on then turn pc on it's posts just fine no problem it goes to windows at this point i can do any thing with no problems i have to make fresh windows but after i finished the windows install screen pc restarts and never come back again the same thing now i have tried to restart from bios and it's same thing (sometimes it restarts just fine + sometimes it's wont to post when i turn pc on )
what i did i tested different ram /gpu/+ integrated gpu /psu/hard drive (it's not hard drive btw it's not posting after restart from windows flash driver or bios)
plus i cleared the cmos many times and updated bios to the latest ver
i just wanna knows is it a motherboard issue or a cpu so i can buy a new one i hope anyone helps my i'am so lost now
specs
ryzen 3 2200g
16gb 2x8 nighthawk teamgroup
gtx 1650 super
mobo gigabyte b450m gaming
psu P550B gigabyte
https://linustechtips.com/topic/1299967-pc-sometimes-wont-post/
Could be a faulty MOBO
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
https://linustechtips.com/topic/1299967-pc-sometimes-wont-post/#findComment-14436747
18 minutes ago, DoubleTake said:
i think so i just asking here first cuz i cannot get another cpu or mobo to test so when i buy a mobo just make sure it's mobo not cpu thanks for fast reply :DD
Weird problems that can not be explained are usually PSU or overclock related. You say you tested many components what did you do to test them and determined they are fine ?
https://linustechtips.com/topic/1299967-pc-sometimes-wont-post/#findComment-14436838
  • 1 month later...
Update after a long time it was a mobo its now has been replaced for a new one i thought at the beginning its will be gpu cuz last thing i dose before the issue is update the driver but now after testing everything except mobo i just rma it i hope this helps this awesome community
https://linustechtips.com/topic/1299967-pc-sometimes-wont-post/#findComment-14554189
