-> Moved to Programs, Apps and Websites
They use Excel and template 11. And then tweak the colors to match what they need to show. For the product info, those usually come directly from karketing or press briefs, with some minor image tweaking added.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1299547-info-graphics/#findComment-14433457
On 1/29/2021 at 10:31 AM, Badr ftouh said:
Thank you for the info Is there a way on youtube or somewhere i can learn how to get started with it ?
With what exactly? Making graphs on Excel/Calc/Sheets? Or with photo editors like Photoshop/Gimp? Or with Premier? With After Effects? Thats about all of the software LMG uses to make videos.
With Excel its just data, select data, insert chart, select theme, adjust range and you are ready to go. Then you copy-paste that to image editor and select by color, then replace with colors you want (Excel can be annoying with colors). Another thing is that I don't quite know what kind of set of data they are using.
https://linustechtips.com/topic/1299547-info-graphics/#findComment-14439653
