I've recently bought a new 120hz 1080p monitor, but in most of the games I play, my FPS tends to be fairly low because I have a very old and fairly low end computer. I was honestly surprised considering the only games that I play are not intensive in graphics at all, like minecraft, and starbound, and geometry dash, and I don't have any intentions to play any games that require a lot of GPU power (nothing triple-a.) I was wanting to know if there was anything that I could do to increase my gaming performance, or any new hardware I could buy at under 200 USD or slightly above that.
My specs are currently:
GPU: Intel HD 4400
CPU: Intel i3 4170
PSU: 300w
Motherboard: 088DT1
I've had my computer for about 4 years and I don't believe I've ever opened it up before.
My case is a dell inspiron 3847, and I've never built any computers or bought any computer hardware before, I'm actually very new to computers in general so I'm not entirely sure what I need to specify, so tell me if you need any other info about my computer. Thank you in advance!
https://linustechtips.com/topic/1299179-help-with-fps/
GPU: Intel HD 4400
CPU: Intel i3 4170
PSU: 300w
Motherboard: 088DT1
you could probably put a used 4770 in there, and then put a used gtx 1050 in there. I have 2000 hours in GD and that should run it at a constant 120FPS (when your not playing intense levels)
Also how much RAM do you have?
geometry is hard
b550 > x570
https://linustechtips.com/topic/1299179-help-with-fps/#findComment-14430664
GPU: Intel HD 4400
CPU: Intel i3 4170
PSU: 300w
Motherboard: 088DT1
SSD + Nvidia 1060 + 16gb Ram
https://linustechtips.com/topic/1299179-help-with-fps/#findComment-14430690
I was planning on buying a 1050ti, since there's one that's 159 and pretty good, and I have 8GB of ram.
https://linustechtips.com/topic/1299179-help-with-fps/#findComment-14430728
159 for a 1050ti is not good. that is very overpriced! (You can find used ones for under 100)
is the RAM in dual channel?
geometry is hard
b550 > x570
https://linustechtips.com/topic/1299179-help-with-fps/#findComment-14430732
31 minutes ago, bungusboy81 said:
I'm not entirely sure about the ram, and where should I buy the 1050ti?
Well in the inside of the PC it will show, if you have one ram stick, it’s in single channel. If you have 2 it’s in dual channel. It’s a bit more complicated than that but I’m assuming you have two dimm slots.
And for the GPU a eBay or Craigslist would be good.
geometry is hard
b550 > x570
https://linustechtips.com/topic/1299179-help-with-fps/#findComment-14430847
Alright, thank you. I'll check the RAM and get back to you.
https://linustechtips.com/topic/1299179-help-with-fps/#findComment-14430866
Probably should have mentioned, in task manager it will say how many slots are used if you check the ram section. Also a program like Hw info or specs will also tell you if it’s in dual channel
geometry is hard
b550 > x570
https://linustechtips.com/topic/1299179-help-with-fps/#findComment-14430877
I checked, and I do have dual channel and it's DDR3.
https://linustechtips.com/topic/1299179-help-with-fps/#findComment-14430921
Ok 8GB isn’t ideal but it’s dual channel and your playing very light games so it should be fine.
So just try to get a 4770 and a 1050ti used. If you find good deals then you can probably get those for $200 total if you find good deals
geometry is hard
b550 > x570
https://linustechtips.com/topic/1299179-help-with-fps/#findComment-14430946
Thank you! Is there anything else I should know?
https://linustechtips.com/topic/1299179-help-with-fps/#findComment-14430961
Nothing really. When buying on eBay try to look for deals where they have taken an actual picture of the product, not just some stock photo. Also if your experiencing crashes and shut downs once everything is installed you may need a new PSU.
geometry is hard
b550 > x570
https://linustechtips.com/topic/1299179-help-with-fps/#findComment-14430985
