Hi everyone!
Please note that this build will be started after my exams have been completed, so please do not get your hopes up until then.
This will be my first ever build for school and gaming purposes. My current PC is a hp pavilion with a centurion processor, 1gb of ram and ...250gb of storage? So knowing this, you can tell how hyped up I am. I am currently working part time and hopefully, in the near future, I will be able to do a water cooled build log of this PC.
Now back to business. The spec on this computer will be as followed:
Case: Corsair 350D (pre-ordered)
PSU: Corsair AX760i
Mobo: Asus Maximus V Gene
CPU: Intel i5-3570k (more info below)
Memory: Corsair Vengeance 8gb (4gb x 2)
GPU: 2x EVGA GTX 650 ti Boost 2gb
Cooler: Corsair H100i
SSD: Kingston 60gb
HDD: WD 1tb Black 7200rpm
Monitor: Benq XL2420T
Keyboard: Microsoft Sidewinder X4
Mouse: Cyborg R.A.T 9
Headset: Tritton 720+ 7.1
Now for the important part. This question is directed at some of the more advanced members. Would it be worth the trouble in waiting for haswell as well as buying an Z87 mobo as opposed to a 3570k and a gene. Personally, i do not like to gamble on motherboards. The Gene is probably the best micro-atx mobo and i'd doubt there will be any up coming ones that will be able to match it.
I am choosing Intel for the specific reason that I am living in a dorm in the UK and energy efficiency does play it's part.
So..., I am all ears for any opinions as well as any improvements.
:D
Project Depravity: £850 / ????? (03/12/2015) Case: Phanteks Enthoo Primo SE Red Keyboard: Corsair K95 RGB MX Red Monitors: 3* Asus PG279Q Stand: Ergotech Triple Desk Stand Webcam: Logitch C920
RIP in kill: CPU: Single core Celeron M @1.73GHz RAM: 1GB (512MB x2) DDR2 SO-DIMM Motherboard: Asus MOCA-AR HDD: 160GB SATA2 5400rpm
Current System: CPU: Intel i5-4690K Cooler: Cooler Master Hyper 212 EVO Motherboard: MSI Z97 Gaming 5 RAM: Kingston HyperX Fury 8GB 1866MHz GPU: Gigabyte Windforce 960 4GB SSD: Sandisk Ultra Plus 128GB HDD: WD Caviar Blue 1TB PSU: Corsair CX500M Case: Corsair 200R Windowed MonitorLG 22MP55HQ 22" IPS + HP w19 MouseRoccat Savu Keyboard: Corsair Raptor K30 Mouse Pad: Perixx DX-1000XXL Headset: Kingston HyperX Cloud OS: Windows 10 Pro 64-bit
https://linustechtips.com/topic/12989-my-first-build/
Ooo so you're going for 2 650ti boost cards eh. Here's a vid by Kyle of Newegg on it's performance
Wouldn't change much actually except for maybe uping that 60gb ssd to a 120gb one?
Oh as for Haswell, ASUS will definitely come out with a M-ATX board similar to the Maximus V gene as the always do with each new CPU released.
Haswell will also be more power efficient so keep that in mind :)
Looking forward to the build sir and good luck with your exams  :D
Join the LinusTechTips Star Citizen Org :D ~ https://robertsspaceindustries.com/orgs/UOLTT
https://linustechtips.com/topic/12989-my-first-build/#findComment-138789
I would suggest you get one 670 instead of 2 650ti's, you will have much less issues with drivers AND power consumption will be a lot lower (since that is an important factor in your case).
That also gives you the opportunity to upgrade to a second 670 in the future.
About the processor; It's quite simple. As Linus said: if you need the performance right now, go for it. If you can wait a while; wait, because haswell will most likely be an improvement of about 15% in performance/Watt at the same price tag.
Also, you might want to get a bigger SSD if you're not planning on using it as cache only.
Good luck with this build!
Cooler Master 690 II Advanced - I5 2500K @ 4.5Ghz - Geil Enhance Plus 1750Mhz 8Gb - ASUS ENGTX 570 DCUII - MSI Z68aGD65 - Scythe Mugen 2 Rev. B - Samsung 830 128gb and Crucial m4 128gb - much other stuff not worth mentioning
https://linustechtips.com/topic/12989-my-first-build/#findComment-138792
Looks pretty sweet. Rumors are that Haswell will be 10% to 15% faster than Ivy, but
even if that's true, as you say the platform is certainly not very mature yet. 1155
has had time to have the bugs and kinks worked out.
Whether or not this is worth the risk is up to you. I would say it also depends on when
exactly you will be able to start this build in earnest. If you have to wait until Haswell
is here anyway (or almost here), you might as well read some reviews then and get an
impression of Haswell that's based on facts instead of rumors, and then you will be able to
actually make an informed decision that's not just based on conjecture about Haswell. ;)
BUILD LOGS: HELIOS - Latest Update: 2015-SEP-06 ::: ZEUS - BOTW 2013-JUN-28 ::: APOLLO - Complete: 2014-MAY-10
OTHER STUFF: Cable Lacing Tutorial ::: What Is ZFS? ::: mincss Primer ::: LSI RAID Card Flashing Tutorial
FORUM INFO: Community Standards ::: The Moderating Team ::: 10TB+ Storage Showoff Topic
https://linustechtips.com/topic/12989-my-first-build/#findComment-138813
Agree with Thib up above.  Especially on a 1920x1080 single monitor, single GTX 670 or R7970 will do you fine.
Edit:  Also, beef up the RAM.  Throw 32GB on there and use 24 of it for RAM Cache.  Makes way more sense than using an SSD for Cache and it's much faster.
My Stuff:  Corsair Obisidan 550D - Phobya Nano-2G 120mm x 5 - Corsair H100i - MSI Z77A-GD65 Gaming - Intel 3570K - G.Skill 8GBx2 1866 - EVGA ACX GTX 780 3GB SuperClocked(Step Up to 780 Ti) - Samsung 840 500GB SSD - WD Black 1TB x 2 - LG Blu-ray - ASUS VG248QE + ASUS PB278Q - Corsair M65 with MM400 Pad - Ducky Shine II MX Brown with Gray/White Keycaps - Corsair K70 MX Red - CoolerMaster Quickfire TK MX Brown - Ducky Pro2 MX Blue with Gray PBT Keycaps - Ducky Pro2 MX Clears with Gray/Blue PBT Keycaps - Ducky Pro2 MX Browns with Light Gray and White PBT Keycaps
https://linustechtips.com/topic/12989-my-first-build/#findComment-138825
Thank you everyone for your feed back. I am grateful for all your responses and well as the improvements.
@XiaoPigs, As the test shows, the boosts have the advantage. But as an in-progress overclocker, which do you reckon will be better in performance, efficiency and aesthetics? Keep in mind that I will be water-cooling it in the near future which should be taken into consideration.
@ThiBaudV, Thanks for your feedback. I will be patient and wait for the upcoming goodies. Also, any rough estimated on the average overclock capable on the cpu's?
@XiaoPigs, I will consider changing my boot drive from a 60gb, to a 128gb (If i can fit it in my budget)
@ARod, I am still not fully computer literate, but I must disagree with the 32gb of ram. At the most, I will only need 16gb, which I may upgrade to in the future. But as of now, I will be good with 8gb. (also I will have to look up 'Ram Cache')
https://linustechtips.com/topic/12989-my-first-build/#findComment-139028
With Haswell (correct me if I'm wrong), the VRM controller will be integrated in the processor, which means that the motherboard will have much less of an effect on your overclocking capabilities.
About the overclock itself, I guess (unless you're really unlucky) you should be able to hit 4,5Ghz-4,8Ghz and if you're really lucky 5+Ghz.
This is of course not yet officially confirmed, but I made these conclusions based on rumors and what we have seen in the past.
https://linustechtips.com/topic/12989-my-first-build/#findComment-140226
Latest Update according to your requests. May take a while to get the rest of the money.
https://linustechtips.com/topic/12989-my-first-build/#findComment-153926
So... this is the new Maximus VI Gene Z. Reckon I'll be able to get this and haswell for £370?
https://linustechtips.com/topic/12989-my-first-build/#findComment-161730
