Budget (including currency): 4000 USD
Country: Switzerland
Games, programs or workloads that it will be used for: Games
Hi All,
I am building my very first PC and the PSU that I have is a Corsair HX1000 and according to the manual, the PSU comes with 8x PCIe cables however each one of them seems to have only 7 pins on the end that goes into the PSU? I bought an RTX 3090 Aorus Xtreme and I know that one needs a lot of power. Is it normal for the PCI-e cables to only have 7 instead of the 8 pins? Please see picture attached.
Thanks!
Eddy
https://linustechtips.com/topic/1298365-psu-pci-e-cable-question/
Hi All,
Thanks!
Eddy
Doesn't matter. There are probably 2 cables linked somewhere into a single connector, saving them a bit of copper on the connector. As long as the end that goes to the gpu has 8, your are good to go.
You are right, I took a better look and it does seem that one of those pins has 2 cables going into it.
