im using a 5.1 setup with the integrated realtek audio on my msi z77a-g43 motherboard. Why and how can i make music and everything play using the 5.1? some games i can hear it but i really want music to use it. I saw reading online that you can check the speaker fill option but i dont have that option to choose from. Thanks :)
https://linustechtips.com/topic/129791-51-help/
what do i need to do?
idk, find software that works to do that. I wouldn't know since I never bothered.
If you have the X540 Logitech set you can set it to 'matrix' mode
otherwise you can try something like SRS sandbox or something.
Error: 410
https://linustechtips.com/topic/129791-51-help/#findComment-1728254
