Budget (including currency): 5000 cdn
Country: canada
Games, programs or workloads that it will be used for: gaming and video editing
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):
I would need monitor 1080p 180hz to 240hz and possibly get another later on, mouse+pad, keyboard, would like atleast 16 gb videocard and possibly another one later on as well
https://linustechtips.com/topic/1296257-first-build/
get a 1440p one... 4k at monitor size/distance from your face is pointless
Unless you need 4k for some reason get a 1440p one...
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
https://linustechtips.com/topic/1296257-first-build/#findComment-14409394
1 minute ago, Rantane said:
U got a point there thanks
No problem 🙂
System Specs
Peripherals
<Razer Mini>
https://linustechtips.com/topic/1296257-first-build/#findComment-14409418
Country: canada
https://linustechtips.com/topic/1296257-first-build/#findComment-14409440
Country: canada
would not reccomend getting another video card because sli is useless shit nowadays
https://linustechtips.com/topic/1296257-first-build/#findComment-14409446
https://linustechtips.com/topic/1296257-first-build/#findComment-14409500
1 minute ago, Avocado417 said:
well i made time to make a list look who didnt
ill make one if you want me too, lol.
Country: canada
geometry is hard
b550 > x570
https://linustechtips.com/topic/1296257-first-build/#findComment-14409541
