Decided to give Ryzen Master a spin.
The problem:
I can't.
I download the installer, run the executable, it shows "extracting AMD Ryzen Master.msi", bar finishes, a window flashes briefly on screen but it closes before I can do anything.
Anyone know what to do?
PLEASE STOP [Killing] ME I WILL GIVE Y OU ANOTHER DEAL.
https://linustechtips.com/topic/1295986-ryzen-master-not-installing/
The problem:
I can't.
Using this link?
https://www.amd.com/en/technologies/ryzen-master
“Appear weak when you are strong, and strong when you are weak.” - Sun Tzu, The Art of War #muricaparrotgang
Tier Lists and Specs List Below
Motherboard VRM tier list  -----  PSU tier list
React if you agree with me!
CPU: Ryzen 5 3600  |  CPU Cooler: Asus ROG STRIX LC240 White |  RAM: Crucial Ballistix RGB 16GB 3600 | Mobo: ASUS ROG STRIX B550-A  |  SSD: Inland m.2 NVMe SSD 256GB  |  HDD: Seagate 2TB 7200RPM |  GPU: RTX 3060 Ti FE  |  PSU: Seasonic SGX 650 |  Case: Lian Li o11 mini-W  |  Mouse: Razer Basilisk mercury |  Keyboard: Drop CTRL (Used. I did not spend $200 on a keyboard) |  Mouse Pad: Aura Mech Purple Storm  |  MonitorAsus TUF 24" IPS 144Hz 1080p
1 minute ago, MarvintheParrot said:
Yep.
Downloaded it again to make sure - 131MB, right?
