Hi there, i am a first time builder and i have a question, i have a ryzen 7 3700x and i have an asus b550-f wifi which has a 8+4 pin cable to power the cpu
My question is, is it i fine if i just plug them both eaventho i am not planning on overclocking,because many people say that 8 pins are enough, so i am wondering if it is just fine if i put both cable eaven whitout oc my cpu
https://linustechtips.com/topic/1295923-cpu-power-connectors/
It won't hurt anything.
Remember, power is not a "push", it's a "pull".
You could make an AM4 board with 20 8-pin CPU power connectors.
And you could hook them all up.
And it wouldn't matter in the slightest.
PLEASE STOP [Killing] ME I WILL GIVE Y OU ANOTHER DEAL.
https://linustechtips.com/topic/1295923-cpu-power-connectors/#findComment-14406917
Oh ok tnx
https://linustechtips.com/topic/1295923-cpu-power-connectors/#findComment-14406927
